vacuum pipes replacement
Hi,
Could you please advise.
i would like to replace all of the vacuum pipes including the main servo pipe.
Would anyone be so kind and advise how many meters (or feet) of what ID pipe will i need to complete the job?
Car is Octavia 1.9TDI AGR engine, with EGR & ASV removed.
At the moment i can not just take all the old pipes out to measure them, as i need to drive the car on daily basis and have not got time to do it.
Many thanks in advance.
Edited by AlbertS
Since there was no respond, maby some one knows what sort of lenght of the vacuum lines would a standard AGR engine require.
I just need a rough idea to order them from ebay, more important, what ID's and OD's are needed.
Ta,
Phone your local Skoda dealer and ask them... that is what I did (but then I ordered the stuff from them as well).  What I can remember is that there are 2 sizes, but I can't recall the details offhand.
thanks for your reply mbames.
i have ordered 2m of 3mm ID and 2m of 5mm ID, of what i have gathered by searching the net.
will see how that will work.
