ecu replace - possible ?
Looks like my ecu is knackered.. air intake temp sensor reads 133degrees even when sensor is off.
Also radiator temp sensor reading v hot from 1st second.
Is it poss to get 2nd hand ecu and code with vagcom ?
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 K HW: 028 101 223 7
Component: R4 1,9L EDC G000SG 7002
Revision: 12345678 Serial number: SKZ7Z0E2968456
Coding: 0000071
Shop #: WSC 01286 386 08256
VCID: 2B5F1FEC8AFBF146111-807E
2 Faults Found:
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00101100
Temperature: 21.6°C
Temperature: 19.8°C
16497 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Temperature: 133.2°C
21.6°C
Temperature: 19.8°C
Readiness: 0 0 1 1 1
ECU failure is virtually unheard of, in the case your experiencing you need to carefully check the wiring for any damage / water ingress/ bent pins from the sensor as it sounds like you have a dead short circuit causing the sensor to read its maximum possible value.
Changing the ECU requires a dealer to recode the dashpod and ECU as the two are paired together for the immobiliser function, if you just swapped the ECU then the engine will not run. You'll also have another problem because the mileage is recorded in the ECU and it cannot be altered, so your dashpod will say the correct mileage, but the ECU will have a totally different figure. Not itself a problem, but if your donor ECU has a higher mileage it could lead to a clocking claim down the line.
Dead short in the feed from sensor ?
As id guess dead short in power to sensor would blow a fuse ?
Worst thing is.. sometimes engine will start.. no light comes up
Then.. 20min later.. light comes on to say fault
Also..
Engine wiring loom im told is..
03G 972 619
But i see varients of it on ebay...
Dl / ab / ap :-(.
Are they all diff types ?
