sytec fuel pump
Yes that's the ticket
Thats a bargain compare to say apr or even that bosch 44 thing is it ?
It's the only one that fits a must in 1.8t
Direct swap is it ?
Is this not a upgrade ?
Or is it more effort fitting
http://pages.ebay.com/link/?nav=item.view&alt=web&id=150523915757
The sytec is a direct swap
There are no off the shelf in-tank brackets for the 044, so kits like that mount them in-line - so you still ideally need something like the sytec as a lift pump
Ah i see
So the syntec thing is all you'd need unless want monter power ?
Beyond k250/280 or 300s
The sytec is perfect for K300 setups, approaching 350ish hp would have thought
A dual sytec in-line setup would be an interesting option instead of a 044 for BT setups - would be much quieter & potentially smaller, maybe cheaper too
Inter-mer-esting :)
So if i ever changer a turbo (any) it wiuld be worth popping 1 of these beasties on
apparently they don't fit the 4x4 though :thumbdown:
They have the split system due to the split tank to allow the prop shaft.
all you need is t-piece to feed the 2nd pump outlet
2nd pump is a venturi
