leaks in Octavia
Hi. I have got a water leak from somewhere in the front drivers footwell. I have read the forum. Is there any newer info or has the problems been sorted with the change of windscreen etc?
Edited by alun5259
First check the scuttle drains are not blocked, if the water level rises above a certain level it can get in through the various routes between engine bay and cabin.
You'll need to remove the wiper arms then gently ease the left and right panels from the windscreen bottom, then check the drains.
