Facelifting headlights.
Good evening all, I'm new to the group and also new to these little go-karts. Quick question, we have a 2014 Citigo with the H4 headlights, is it possible to fit the facelift headlights with the LED DRLs to it?
I'm not sure, but the bumper may have changed for the facelift, so watch out.
If they do fit, go for the lamps with twin H7 bulbs (and LED DRLs) - they are massively better.
I tried changing my dual bulbs (half running lights half side lights)
I put in the led bulbs (blew a fuse (that was not fun finding))
I have now taken them out.
and put in the tinted bulb to remove the yellow glow.
  • 5 months later...
I have fitted facelift twin h7 headlights to my daughter's 2013 Elegance without any issues. You will need to get the connectors that plug in to the headlight unit together with some of the wiring to solder to the original loom.
  • 2 years later...
Hi Simon, do you have a wiring diagram that you followed to connect the facelift headlights for a pre facelift citigo ? I’m doing the same mod and I’m struggling a bit. I’ve located the pins for the main bulbs, but got lost with the leds and adjustment’s motor. I already got the female connectors
I forgot to quote you in my previous post, so here it is again.
I seem to remember that the colour codes on the wiring was the same on both sets of headlights.
Thank you Simon! Do you have a pic of those wire ? I need to see in which order they need to be pinned into the 10 pin connectors.
Sorry I don't have any pictures of the wires. I used second hand headlight connectors which came with a short length of wiring attached. The extra wiring was needed to extend the harness as without it there is not enough length to install the headlight as the socket on the headlight unit is in a slightly different postion.
