2006 Octavia 18255 P1847 Please check DTC Memory of brake system ECU
Hi
my first post here but have bin following and reading all the great info here in the past help me a lot  both on my 2012 superb and  2006 octavia
i have this fault code on my 06 octavia 18255 P1847 Please check DTC Memory of brake system ECU any no how to trouble shot this . already check all fuse and so on any help on this matter please
Kind regards
Bo
Edited by VRSCD
Any faults stored in the abs controller?
Which controller showed that fault and are you using VCDS or some other fault code reader?
hi I had bad rear left ABS sensor that i replaced and the fault is not active now  after replacing the sensor ,  the auto transmission store this code P1847 in it and it like to stay in the gears will not sift up above second gear exempt going manual but the down shift is fine, No fault found on the abs , i am using OBDll code reader
You would be best off using VCDS.  I have no idea whether we have any Briskoda members in Iceland with VCDS, but I should think a VAG specialist garage will have.
