Tail lights on with DRLs coding found (hopefully)
Been doing some searching for the coding adaption for having the tail lights on with DRLs. I emailed vagtechniek in the Netherlands after reading a topic on http://www.vwupforum.nl/ and received a reply saying to use the long code helper in vcds and to set byte 12, bit 0 to 1. Now I have never used VCDS and would like some help from someone here who knows what they are doing. How does the long code helper work?
probably better off asking in the Diagnostics and VCDS sub forum of the Technical, Performance & Tuning section I would have thought.
Can a mod move this to the correct section please?
Guest
