vrs 18" tyre pressure
What should the psi be on these tyres ?
Look inside the fuel flap. There should be a sticker in there with the tyre pressures on them for tne various loadings.
From memory i think my vrs is 2.1 bar front & 2.0 bar rear. littleade the op's profile says he has a 1.9tdi octavia not a vrs so im guessing he has a set of vrs wheels to fit to his car hence the request? I could be wrong though... :D
I have put in 2.1 bar front an.2 bar rear however the tyres look like there low /:
And yes I have the vrs wheels on my 1.9
I didn't spot that, ooops! Anyway if it is a 1.9 I have no idea because the tyre pressures for a vRS also take into account that the vRS is heavier so he may well have to contact the tyre manufacturer to get a definitive answer.
I run 35psi all round on my Vrs on 18s.
The fuel flap reccomends 29psi? Personally I think that would cause problems.
But most on here run 32 front and 34 back.
I know of a few running 38-40 but causes a few problems in the wet.
So yeah if you run 32-34 you'll be fine and not experience any under or over inflated tyre problems etc
I really really should read the previous posts BEFORE I post my 10 pence lol.
Considering it's a 1.9, who knows.
Good luck!
Good luck!
Shouldn't really make a diffrence really and 32/34 is what I will be running
