K&N air filter
Hi guys,
I can get a K&N air filter for
Suspect little to no difference in power, unless your current air filter is really dirty and then you might notice a small difference. There will be more Induction roar though as more air is flowing through the intake :D
Chris
is this a panel filter or a cone filter you will find if its panel small noise diffrence if any at all.... if its cone there will coudl be quite a large diffrence in noise...simply cos you will do away with the plastic air filter box that muffles the noise
Joel
As Joel said you'll probably get more noise with a cone filter BUT, I suspect a little less power due to hot air from the engine...although I must admit I'm not entirely sure if hot air affects an NA engine the same as a forced fed one.
I suspect it does just that a forced fed one get more air in so the effects are more noticieable....ho hum.
I put a K&N panel in a few hundred miles ago when it was in having its 20,000 mile service and there was a definate improvement in the upper revs ie it pulled cleaner round and for longer. This might also have had something to do with the oil flush and change but Im convinced its worth the money myself :)
Lee
thanks very much, top man, he's sent me some pictures through, im gonna have a look tomorrow, see if it will fit.
thanks for your help guys, appreciated as always.
chris
Hi Chewy, I've got one of those K&N filters, all boxed and very few miles in use. I removed K&N from my LX 1.6 sport before trading in for 4x4 hatch and as it's a different filter it didn't get any further milage! PM me if U R interested and want to save some
