Octavia 4x4 Speed/revs in top
Does anyone know the speed in MPH per thousand RPM in top for an Octavia 4x4 with the std 5 speed box ??
Stuart - I will check this on the way home and post back the findings. :)
Lee
I think it's around 21-22mph/krpm, Lee should be able to give a definete answer though.
Will this do?
Looks like it's 21.6mph/krpm then so I was in the right ballpark. Which ties in with me doing 155mph when hitting the 7.2krpm limiter.
Is that the standard figure for the limiter, or should it cut in at 6700rpm?
Not sure as I've never driven my car on a standard map. My limiter is currently set at 7200rpm, I think Stuart's is 7500rpm.
Thanks guys
i have no idea what my limiter is set at what so ever, would jabba raise it as a matter of course when re-e-mapping(bo) the car?
Probably, I doubt it's as high as Stuart's but almost certainly higher than standard.
