Air con & abs pump.
Hi guys I have a full air con system if any of you guys are looking at fitting air con to your car iv got the compressor, the longer serpentine belt, condenser, pipe work, fan blower unit and the controls in side, I don't know what is worth....... make an offer, star at £100?!?
I also have an ABS unit that came off a working running car, no abs light on on the dash never tried it out when the car was drivable but assuming its perfectly fine again no idea what there worth £40?
Both came from a 1999 T reg 1.6 petrol car, I don't want them Id rather somebody in need/want makes use of them contact me to hash out a price ;-) can deliver or meet if local (Wiltshire bath/Swindon area) or can sort out a carrier at cost though work. can get pics if wanted.
That's a rare find nowadays folks, the numbers of these cars in existence is dwindling rapidly by the year now, ones with aircon are super rare.
have you got all the wiring harnesses and switches etc?
Hi there you need the dash and engine loom theres loads needed to convert power steering pipes.. aux enginge hanger fan and rad stater to alternator wire and the tem plate for the hole in bulkhead... i converted a 1.3 to 1.6 one and now going on a fun hope this helps and in is a rare find to some one....
I have the engine out to keep as a spare/fettle which has the compleat loom on it still, I was going to take the big alloy hanger that holds the pas pump and all that off to supply with, I have the controls out of the dash yes, if needed as there differant them yes i have pas pipes, before I stripped it i had the gas removed it was still holding gas so rad is in good condition.
