can anyone help?
Can anyone help? I did some logs earlier with vcds but struggling with putting the data into a graph? :(
I have attached the file below.
I logged blocks
120-Torque/bhp
115-boost
114-boost
115/114 actual and requested
Im BOB with this sort of thing
TIA
LOG-01-120-115-114.CSV
These are a bit Mickey Mouse as I haven't got much time at the moment, but perhaps these might be of use? The charts are very busy due to number of data series, and I'm not sure what series you need plotting against what.
Regards M
GROUPSBandC2 .pdf
GROUPSBandC.pdf
GROUPA.pdf
Minimoke thank you very very much :)
Main one i was interested in was actual vs requested boost.
I think max actual boost was 1780 m-bar
Is that what you wanted?
I hope I have plotted the data series you require - unfortunately I'm not over familiar with what you are trying to do, so I'm guessing a bit about which are the correct data series.
Go to go now - the dogs is not well and sometimes throwing up copiously!
Regards MM
BOOST2.pdf
BOOST.pdf
Proper legend thank you very much
