Dump Valve Silicone Hose Length?
As above. Does anyone know the size silicone hose is required for a forge 007? I know its pretty thick.
Just checked, (assuming its the top DV connection your asking about).
The Forge hose I used :-  I/D of 6.5mm, O/D of 15mm x approx 300mm long.
NB: Mine does rub against the edge of the large engine cover and it has worn a small flat on the hose. I'll have to cut cover back locally at some time.
If u mean relocating hose, its 25mm id iirc
No sorry. Its the vacumn line. Should of said!! Haha
Ha ha i didnt read it was length u wanted either :D
Post fail ;)
Length not too fussy about was going to order a 3mtr cut anyway. It was the thickness in mm that I needed.
