2.0 Tfsi Bwa - Camshaft + Hpfp Worn.
Not a Skoda, but a Leon I have just purchased pretty cheap. I bought on the assumption it was a misfire at high revs, however, after stripping it down I found the following:
Worn Cam lobe for fuel pump -
Snapped bottom guide of tensioner -
Plastic seals broken for Cam Phaser/Variator (whatever its called!) -
Damned revision A cam -
And the car in question, along side my barge -
The cam follower for the HPFP was fine, so had been replaced recently before the car was shifted on to some numpty (me). The tip of the HPFP has worn ever so slightly, I will get pics tomorrow - hoping someone can advise if OK to reuse, or will need replacing, or if parts can be sourced separately for the pump?
And, what is known about the Phaser wheel thing, I understand roughly how it works, with oil being passed through the 3 different galleries, and the plastic seals there to separate them, but would it be safe to use Some similar sized Viton O-Rings?
Annddd, cheapest place to buy a new cam - I have read I can use the S3 cam, revised with hardened lobe for pump. But can it be bought anywhere other than VW/TPS?
Anyone been in the same boat?
Tony.
Anyone got old standard internals from HPFP after upgrading?
Had the same issue at work with an Audi A4 2.0 tfsi worn the high pressure fuel bucket and chewed into the cam shaft traced the fault the begin a failing oil pump gear drying the top end of head up! New oil pump and camshaft and bucket later all ok but that was mega ££££ begin main dealer etc!
Sadly I don't know of any spares going dude but as for using a S3 cam shaft that's the best way forward
Hope this helps
I thought all the BWA's came with Rev B cam? Only the early Gti's came with Rev A.
I'd just get the Rev B cam.
Will the S3 one fit? they have different compression ratios.
Oh and I'm sure I have some pump parts in the garage.
Edited by martziniuk
Hope this helps
Did the engine run ok otherwise - What was the symptoms?
I think suffix J is the newest updated cam replacing the B, H is the S3 one. From what I've read it is fine to use, plenty of people have had no problems and they are all the same price.
I'll pm you now about the parts mate.
EDIT/ Tried to PM, your inbox is full I think?
Should be ok now.
sent mate.
Thanks mate, sent and replied to.
Has anyone got a cam going cheap?
:D
:D
I'll have a look in my shed. I've got my old engine in there.
Edited by Harry_vRS
Pretty please - PM coming your way! :)
Edit / DOH, PM box full!
Inbox cleared. PM sent...
Replied mate, thanks for your help.
