Help! Interior Door Trims...
Hi guys, I don't usually post on here but in need of some help. I just wanted some help with my interior trims on the doors (silver bits) in my octavia mk2..
Any idea how I remove them without snapping/damaging them?
I want to wrap them :)
Hi,
Door trims are held by melted pins at the back, take the door card off you will see what I mean, the one at the front above the glove box is fixed by nuts need to remove glove box first, the others just "pop" out with the aid of a small flat blade screwdriver.
Hope this helps.
Trev
Hi,
Hope this helps.
Trev
Thank you.
I think I'll leave the door trims until another day, I'll just do the bits on my dash that I know for now [emoji3] .
Thanks for your help
Your welcome, that's what this site is about, helping each other.
Trev
Takes 10 minutes, break the tabs off and hot glue the trims back on. It's all I did when I had mine flocked.
Wrap them in situ...
