1.9Tdi Caliper Carriers
Ive had an issue with my front drivers side caliper carrier. the threads that the pins for holding the caliper on are gone the pins slip in and out i cant tighten them atall. I have nuts and bolts in just now was a pain getting that done. Question is does anyone know the part number for just the carrier i cant see one on it anywhere.
Can you see FS-III stamped in the front callipers?
Yeah there is so.
You haven't said what year your car is, but I don't believe the FS-III calipers changed over the years. This diagram may help you find what you need:
http://www.partscats.info/skoda/en/?i=cat_vag_models&brand=sk&number=81&set=96&ein=2007&f=419&hauptgr=1234567890&hg=6&grf=061516253&bf=61520&hgug=615&ug=15&parent_id=109460
However from what you have said I'm not sure if you have actually damaged the wheel bearing housing assembly itself, in which case see part 6 in this diagram:
http://www.partscats.info/skoda/en/?i=cat_vag_models&brand=sk&number=81&set=96&ein=2007&f=419&hauptgr=1234567890&hg=4&grf=040700409&bf=40700&hgug=407&ug=07&parent_id=106335
Sorry yeah its a 56 plate those diagrams are exactly what i was looking for looks like im going to need the wheel bearing housing. Had a look and thought the caliper carrier could be changed itself but doesnt look like it. Thanks very much for helping out
