Superb 3T5 reversing camera
Hi Folks,
I've recently installed a reversing camera on my Superb Combi (which involved attacking the tailgate with a Dremel :peek:) . All of the hardware is in (camera: 5N0 627 566, camera control module: 5N0 907 441A, camera fixing bracket: 3C9 827 229C) and the cable has been run and plugged into the back of the Columbus unit. Power supply to the controller is connected and can-hi & can-low are also connected.
Due to a lack of info on this, its all been a little experimental up until now.
The problem I am having is the coding of the 6C backup camera controller, despite my best efforts, the controller will not accept ANY coding changes whatsoever, i keep getting the 'out of range' error code. I have tried non zero WSC/Importer codes etc. but no luck.
I've registered the camera controller in the canbus gateway (6C backup cam) but the coding is the main issue, it also throws up an error code 01042 (control module not coded).
Via the measuring blocks, the controller can read the steering angle, reversing signal etc so I know it's alive in that respect.
I've tinkered with a few settings in the park/steer assist to allow for the camera's presence but it all comes back to the total inability to change any coding on the controller.
Can anyone suggest anything? other than smashing it with a hammer? is it borked, perhaps? I've attached my latest scan if it helps.
T.I.A.
Wednesday,19,November,2014,12:17:56:39432
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Workshop Code: 166 03246 013427
VIN: TMBKF73T8E9015256   License Plate: ---
Mileage: 49360km-30670mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 61 62
          6C 72 77
VIN: TMBKF73T8E9015256   Mileage: 49360km-30670miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RR    HW: 03L 906 018 MH
   Component: R4 2,0L EDC   H28 5266
   Revision: 41H28---    Serial number:
   Coding: 00190012042501080000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM20TDI01103L906018RR 003003
   ROD: EV_ECM20TDI01103L906018RR.rod
   VCID: 0B1E10E3A2DF58790A9-805E
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 863D6016092300FF610D06E9901F0092340000
   VCID: 7DFA4E3BE46B66C904D-8028
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
   Component: Climatronic   H19 0607
   Revision: 00001008
   Coding: 0018000003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 7CFC433FF7716FC1333-8029
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
   Component: BCM PQ35  H+  112 0771
   Revision: AF112771
   Coding: 48010AB8E86BF1C0400800C0310089EC4BF800E0732187208089E7040041
   Subsystem 1 - Part No: 3T2 955 119 B
   Component: Wischer 30061  26  0700
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 080713 05  54  0403
   Coding: 062BED
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 B    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0010
   Revision: --H11---    Serial number: 32961318501575
   Coding: 108002
   Shop #: WSC 33361 790 00085
   ASAM Dataset: EV_EPHVA14SKxxx0000 002001
   ROD: EV_EPHVA14SKxxx0000_SK46.rod
   VCID: 346CAB1F9FA16781BB3-8061
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LDM VW10 HI   2118
   Revision: 24019000    Serial number: 003LEPCYXU66
   Coding: 0017485
   VCID: 4280FDC71D15D93139F-8017
   Subsystem 1 - Serial number: 6332MTS680791713
   Subsystem 2 - Serial number: 6342MTS669541713
   Subsystem 3 - Serial number: 6351HTS6QIDB4CKR
   Subsystem 4 - Serial number: 6361HTS603KF2CKJ
   Subsystem 5 - Serial number: 63727TS685V95CKR
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   016 0140
   Revision: FF010042    Serial number: 20130708300033
   Coding: 1082140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79F25A2BF8435AE9285-802C
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
   Component: E221__MFL-PR6  H04 0120
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 941 M    HW: 3T2 920 941 M
   Component: KOMBI         H06 0811
   Coding: 711E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 3F86F433A6E7B4D9561-806A
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 200613F1002149
   Coding: 352303
   Shop #: WSC 03246 166 13427
   VCID: 7AF04527F54551F121F-802F
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 49364 km
                    Time Indication: 0
                    Date: 2014.11.19
                    Time: 11:46:30
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0811
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AD075678DE5E171D1F-803F
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3001
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 37769C1386D78C999E1-8062
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 686 C    HW: 3T0 035 686 C
   Component: RNS-MID       H10 5269
   Revision: AB001001    Serial number: SKZ6Z7N5210009
   Coding: 04000402000400A11000
   VCID: 3668911781DD7591857-8063
   Subsystem 1 - Part No: 3T0 051 859 Q
   Component: EU West V10  8048
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 49360 km
                    Time Indication: 0
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 52A0CD870D7549B189F-8007
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 195    3501
   Revision: 00H22000
   VCID: 39729A2B70C39AE9685-806C
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51A2C28B087332A9B05-8004
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0111
   Coding: 01C600003F000000
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 37769C138ED78C999E1-8062
   Left_headlamp_power_output_stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo links  H01 0003
   Coding: 8E0000
   Right_headlamp_power_output_stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo rechts  H01 0003
   Coding: 8E0000
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 49360 km
                    Time Indication: 0
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1642
   Coding: 030F185A
   VCID: 71E2620BA83312A9905-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010C00200001001000
   VCID: 50A4C78F03793BA1BFB-8005
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Component: J772__Rearview      0030
   Revision: 00H13000    Serial number: 525PA8-J399331
   Coding: 8388607
   Shop #: WSC 98765 666 38384
   VCID: 2D5ABE7BB48B3649F4D-8078
2 Faults Found:
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 15
                    Time Indication: 0
03006 - Back-up Camera System not calibrated
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 15
                    Time Indication: 0
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H07 0415
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0946
   Revision: --------    Serial number: 35502105026606
   Coding: 020000000100010000000001
   ASAM Dataset: EV_UHVPremi 002708
   ROD: EV_UHVPremi_SE36.rod
   VCID: 244C5B5F2F41F7012B3-8071
End-------------------------(Elapsed Time: 03:42)--------------------------
Interestingly, I just tried connecting a 7N0 camera controller and I get exactly the same issue. I can change any of the adaptations with no problem but I cannot change the coding at all. Seeing as 2 different controllers are behaving the same way, I am thinking maybe it is the CAN gateway causing the issue?
Still hitting the brick wall on this one......
I will try to help you on this as I just fitted a RVC to my Tiguan. I followed this thread and my headunit is a RNS315 (same as Amundsen plus).
http://www.mytiguan.com/index.php?/topic/17474-retrofitting-highline-reverse-camera-in-2014-uk-spec-r-line-177-dsg/
You will need to calibrate it as well.
My VCDS scan:-
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 4572
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190032042701080000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TDI01103L906018E 003008
   ROD: EV_ECM20TDI01103L906018E.rod
   VCID: 2C79DF26472EF441E33-8079
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 BJ    HW: 5N0 614 109 BJ
   Component: J104   C6 450M V430 0014
   Revision: --H07---    Serial number: 00000007988208
   Coding: 0036158
   VCID: 74C90746179EEC817B3-8021
   Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 79D73672F8FC91E9285-802C
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 48180A33E837F3C040A800C8300081EC4FF9AA88437D81206488E7000041
   VCID: 42A5919EDDAA123139F-8017
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 15031  013 0204
   Coding: 009F95
   Component: RLS 270314 05  54  0403
   Coding: 06304D
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Coding: 000000
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56231408101072
   Coding: 349203
   ASAM Dataset: EV_EPHVA2C000000000 002014
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 4BBBBCBAE2E0D379CA9-801E
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__20E VW10 HI   2518
   Revision: 27019000    Serial number: 003L7P6DBPP7
   Coding: 0012357
   VCID: 7CD92F663FCEA4C1333-8029
   Subsystem 1 - Serial number: 6332MTS606200794
   Subsystem 2 - Serial number: 6342MTS600730734
   Subsystem 3 - Serial number: 6351HTS6A9VTNCKJ
   Subsystem 4 - Serial number: 6361HTS65S4UNCKR
   Subsystem 5 - Serial number: 00000000000000000
   Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140319201289
   Coding: 108A140000
   VCID: 7EDD256EE1D2B6D11D7-802B
   Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0037
   Coding: 820000
   Part No SW: 5N0 920 983 D    HW: 5N0 920 983 D
   Component: KOMBI         H04 0611
   Coding: 111F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 364DFD4E8962BE91857-8063
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 180314F1001395
   Coding: 356003
   VCID: 7CD92F66FFCEA4C1333-8029
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 5K0 857 511 C    HW: 8P0 857 511 C
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 0102196B74745D545420363E01
   VCID: 2E7DD52E79328651CD7-807B
Address 22: AWD
Cannot be reached
   Component: IMMO          H04 0611
   Coding: 000000
   VCID: 6AF5193E8D5A2A71D1F-803F
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666027292
   Coding: 020100
   VCID: 2B7BDC3A4A20F379EA9-807E
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C8 035 279 G    HW: 3C8 035 279 G
   Component: RNS315-EU   H77 0410
   Serial number: VWZAZ2P0128740
   Coding: 0400040104000C0000001002
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2F43C82A76388F59C61-807A
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V5  0055
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0504
   Revision: 12110009    Serial number: 0008308251
   Coding: 0212B6
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3957F672B87C51E9685-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C
   Component: J389__TSG-HR  009 1504
   Serial number: 00000008645443
   Coding: 000090
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 202    3501
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 40A19B9613A600212FB-8015
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0504
   Revision: 14110009    Serial number: 0008276528
   Coding: 0213B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3A55E97EBD7A5AF161F-806F
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C
   Component: J388__TSG-HL  009 1504
   Serial number: 00000008637995
   Coding: 000090
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000002080899
   Coding: 0026167
   VCID: 364DFD4E4162BE91857-8063
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1642
   Coding: 030F1859
   VCID: 71C70E52A88CD9A9905-8024
Address 65: Tire Pressure        Labels: None
   VCID: 558F5AC2BC2495896CD-8000
   Revision: 00H13000    Serial number: 525PA8-J399332
   Coding: 0000010
   VCID: 2D7FD222B434FD49F4D-8078
End-------------------------(Elapsed Time: 03:17)--------------------------
I am sure I read somewhere the VW controller can't be used on a Skoda hence why there are no models listed.
  • 5 years later...
Did anyone come up with a solution? - I have this exact same issue, installation all went well, but as dstev2000 says,
"6C backup camera controller.. will not accept ANY coding changes whatsoever, i keep getting the 'out of range' error code.
and
I've registered the camera controller in the canbus gateway (6C backup cam) but the coding is the main issue, it also throws up an error code 01042 (control module not coded). "
Also my Optical Parking system display has disappeared.. just makes beeping sounds now.
Any ideas welcome!!
I fitted a RVC to our SII estate -
I have attached the VCDS of the 6C controller after calibration.
If your OPC is suddenly playing up and you should not have done anything to it for the RVC installation, go back to the last coding where the OPC was working and delete the DTCs. Otherwise it may have coincidentally become faulty.
RVC_cal.txt
