rear fog light
Hello Fellow Yetis,
I would like to have a pair of rear fog lights rather than the single. Never understood this as if abroad, no one can see it on the 'wrong' side...a bit like placing the GB badge on the off side....so removed the lamp unit and guess what the bulb is there, but no cable into the multi plug.
I can't believe they would fit a dedicated RHD loom, so does anyone know if the cable is tucked away further down the loom?
Much appreciated in advance.
Edited by Yanic
This was raised recently here, here & here and the conclusion was that the wiring was not there and wiring it across to activate it would be problematic and that VCDS coding would not allow the option of changing between the single / twin lights without hardwiring in a switch.
HTH
Many thanks for that. You can obviously use the 'search' facility a lot better than me!
I'll leave well alone.
