Fiat S76. 28.4 litres runs for first time in 100 years...
As railway enthusiasts would say "What a beast!"
Bet it is loud on idle would love to have a drive
A brave man to hand crank that..... :o
4 cylinders! :o
+1 since likes are missing
A bit like that Brutus thing  - chuffing huge engine putting out massive (for the time) power through components probably not ideal for the job..
what an absolutely brilliant machine!!!!
Not bad for a fiat ;).
Couldnt quite figure out that hand cranking.
Didnt seem like manually starting usually does. Its a bad do if a fairly big motorbike kicks back unexpectedly, but that thing seemed to crank over after he let go?
I dno. I dont know much about classics. I just turn the key lol.
Read a bit on it and apparently cranking it is a bit scary, the cylinders are hand filled to start with then cranked and the sparks some from a trembler coil. It immediately tries to kill the cranker on starting.
Can't find the article now.....[edit[ it's in the you tube comments
One of the guys in that vid is Mark Walker, who has built and owns a 1905 Darraq. It has a 25.4 litre V8.
I have actually seen him and his car when he came up to Saltburn 4 years ago, where 1908, set the land speed record of 121.57mph.
Uploaded with ImageShack.us
It's an awesome car, I'm sure the Fiat is just the same.
