help with SAI, N249 and N112 removal
Iv read through the guide but im abit stuck. Im in the middle of removing the sai combi valve, im getting confused with where the dv pipe goes. Am i right in saying i remove all 3 hard lines and connect the pipe on top of the dv to the bottom of the intake manifold. Iv ordered 4mm vacum pipe like a few ppl stated in the comments on the guide. Is this the pipe i use from the dv to the manifold?
Yes that sounds right, 4mm I/D piping,
Ok thanks. Is there any pipes that need blanking off?
From what I can remember 2 ports on inlet manifold join them up with a piece of your 4mm pipe, and one on the TIP
