sat nav and information panel not working
How to explain ??? On way from Santander to lisbon. Sat nav fires up but will not show map. Just keeps saying ..... calculating your route!!!! At same time on information panel.... where you get info on mpg etc is not working. All I have is photo of car . Any suggestions???
Is the rear hatch window filled in white on the car picture on the Maxidot, if so your rear hatch door isn't closed properly.
Question should really have been asked in the Yeti section, not technical guides.
Thread moved to correct area.
To be fair this didn't really need to be in the Yeti section as the infotainment is common across models.
In any case, I would try a hard reset. These systems are not infallible and need to be rebooted occasionally.
