Does the belt ect need to come off to fit the cam sensor
On an 05 tdi....I read yes it does then no it doesn't, don't know what's right, I see it near the front of the block just behind the belt and can feel the 10mm bolt holding it. I read that it comes out through a hole at the front by taking a grommet out.....is this right enough or does the belt ect need to come off
I know it can be done on the 1.9 PD engine with out removing the cam belt its a bit tight fit if you have big hands don't drop the bolt
Yes meant to say it's a 1.9.....so can be done, I just asked the mechanic I use, he said the belt ect needs to come off, unless he can't be arsed with it being footery
Does it go on one way, what mean is, is there a locating pin and just blots on or does it have have slots for "movement" to adjust its timing
Edited by Cleo
There's a small locating pin on the back of sensor
I changed mine took about half hour
