The dash illumination has stopped working on my vRS
Got in the car last night, turned the lights on and all of the interior illumination did not come on. I have tried fiddling with the lights switch and I've checked the fuses and everything looks ok. I have got the car booked in at the dealer on Friday to take a look but I had heard from a friend that dash illumination faults are common on Audi's. Is there a similar problem on the Octavia? Any ideas what the fault could be?
Thanks in advance.
I had that, but it was down to a fuse. IIRC it's on the same circuit as the glovebox light, so check if that works. If it doesn't, check that fuse...mine only had a small gap in it where it had blown...
Rob.
Keep in mind that when comparing the fuse layout in the pic on the back of the fusebox cover/manual that they are for LHD so everything is reversed on RHD cars.
Thanks for the replies guys. I'll double check the fuses - I noted that the layout was different to the manual as it is a RHD. I've got a feeling the glove box light does not work - so I'll have another look at the fuse.
Found the glovebox (or stowage compartment in german!) fuse - swapped for another one and it's still not working :thumbdwn: - it was a bit tricky driving in the dark last night when I couldn't even see the speedo :rolleyes:
Let's hope the dealer sorts it on Friday...
  • 4 weeks later...
For anyone reading this in the future, the fault turned out to be the headlight switch. Had it fixed under warranty :thumbup:
Thanks for the feedback. Very useful to have.
