Oil seepage from cam chain cover
On the 1.2 TSI engine has anyone experienced oil seepage from around the plastic cam chain cover on the top of the engine on the left hand side. The gasket looks OK but it appears to be coming from the points where it is screwed down. It's probably easy to fix but nonetheless expensive if the dealer does it. If this is a common problem and the leak remains slight I won't worry too much and just clean up every few months.
If it's under 3 years old, it's warranty - free!
