are the front discs 288 mm?
as title, thanks.
Yes on the Mk2 Fabia vRS as standard.
What you planning Dave?!
288mm is good for the little Fabia. Considering my Octavia weighing over 200kgs more has the same!
Phil
Phil
Does the Octy have rear discs though?
Yes. So does the Fabia vRS I believe.
Phil
vRS = 288 fronts 232 solid rears.
312s fit under 16" wheels :P And 256 vented discs/calipers to suit can be fitted to the rear.
Phil
looking for pads.... plan for next trak season after winter mode.... tarox corsa pads (expensive, but apparently awesome) and you need the disc size to get the right pad....
gonna do the FARB then too, with polybushes (just for the bar, would be stupid not to if its being removed, as at some point I will polybush the whole lot)
and maybe some better shocks, all at the same time while the garage has it in bits :)
basically needed to confirm the disc size for ordering the pads ;)
