need help head light washer
hi converted to xenon and put in headlight washers all the bits needed are there but when i connect the pump to the other pump as most people said to do my rear wiper keeps working no matter where the stork is any help would be great many thanks martin
The headlamp washers only work when the headlights are on, so I would imagine you need a live and earth switching from the lights? I'm no auto electrician so I could be completely wrong lol. All I know is they only work with the lights on. Hope that helps in some way?
thanks will try find out more
  • 2 years later...
Hi, I am also wondering how to wire the pump for headlight washers so it turns on when it's supposed to. I found that I needed the right relay (part number 6U0 955 535) and some sort of wiring loom to properly retrofit the whole system. I am wondering if the Kufatec loom for the Mk4 Golf (https://www.kufatec.de/shop/en/headlight-washer-system-w-o-sensors-harness-vw-audi) with the suitable relay would do the job or I need something more?
Thank in advance for help ;)
