Fault Codes
Checked my car today for fault codes because the EML was on and it turns out i have 10 fault codes
Codes are:
                     VCID: 321799CBED37
2 Faults Found:
01314 -  Engine Control Module
        013 -  Check DTC Memory - Intermittent
00668 -  Supply Voltage Terminal 30
        008 -  Implausible Signal - Intermittent
1 Fault Found:
00532 -  Supply Voltage B+
        07-10 -  Signal too Low - Intermittent
3 Faults Found:
17705 -  Pressure Drop between Turbo and Throttle Valve (check D.V.!)
        P1297 - 35-00 -   -
17544 -  Fuel Trim: Bank 1 (Add): System too Lean
        P1136 - 35-00 -   -
16487 -  Mass Air Flow Sensor (G70): Signal too High
        P0103 - 35-10 -   - - Intermittent
2 Faults Found:
01336 -  Data Bus for Comfort System
        80-10 -  Single-Wire Operation - Intermittent
01304 -  Radio
        49-00 -  No Communications
2 Faults Found:
00929 -  Locking Module for Central Locking; Front Passenger Side (F221)
        27-00 -  Implausible Signal
00930 -  Locking Module for Central Locking; Rear Left (F222)
Any ideas what they are?
Reset them all, take it for a drive and see which ones come back as that seems a lot to me to happen all at once, the ones that come back can then be rectified. Could be left on from previous repairs.
Second time I've had these codes:
        P1297 - 35-00 -   -
        P1136 - 35-00 -   -
On the last two look for split vacuum pipes under the shield at the front of the engine close to the dip stick.
