looking to buy octavia any advice
Hi looking to buy 2.0tdi 2006 octavia sport. Is there anything i should be looking for? any help will be appreciated. Thanks
Uneven wear/feathering of rear tyres, check fronts, they do get swapped around!
Injector recall.
DPF.
Unusual engine/turbo sounds.
Service history.
Rear screen washer operation/water/screen wash in spare wheel well.
Wind noise from rear door/window seals.
Suspension noises.
Sill/floor damage from jacking.
Parking sensors.
Air con.
Rusty top of fuel filter housing.
Mayo on engine oil filler cap/oil level on dipstick.
Correct engine oil used in services.
That's all I can think of offhand, just the usual stuff to watch for really, take a non biased mechanically minded friend along when viewing to have a good poke around while you ask questions.
Good luck.
The Sport version used the 2.0 BKD engine which won't have a DPF or be subject to the injector recall, so that's two less things to worry about.
Cheers guys thanks for the info. Bought the car today and all seems ok so far.  Time will tell. Appreciate you taking the time to reply. Thanks again.
