implausible codes.
So I may be sticking my neck out a bit but if a fault code contains the description implausible?.......
It normally means a sensor is giving a stupid reading. Such as the coolant temperature sensor giving a reading of -50°C.
Hi, no, not a dash warning, just a scan threw up a fault code( don't have number to hand) relating to manifold pressure but described it as intermittent and an implausible signal?
Clear it and see if it comes back. If it doesn't I wouldn't worry too much.
