Skoda Felicia N Registration: Door will not open.
My car recently failed it's annual MOT test.
One of the failure points relates to the fact that the off-side rear door wiil not open.
Has anyone any advice as to the best method to tackle this problem at the minimum cost?
Can I gain access to the internal door mechanism or should I take it to a recommended dealer?
Thank you.
Hello rod smith
Welcome.
You might get an answer in this introduction page, or you could check out or post directly into the "Other Models" forum.
Mo
you cannot fail vehicle on a rear door not opening only the front two.
