VCDS strange behaviour?
I have a genuine VCDS cable running 14.10 software. The cable is a Micro CAN, which works perfectly on my Mk7 Golf. However, on the O3 it doesn't work particularly well in Autoscan mode. When I do an Autoscan it seems to be able to scan some modules without fault and then it says "Cannot be reached" for certain modules (42 drivers door and 08 HVAC are the current favourites).
I can reach the module if I select it and recode it. If I repeat the Autoscan, it is not always the same modules which "cannot be reached". Any ideas on what is going on?
When I start the Autoscan, it seems to be able to see all the installed modules and reports back with no fault found and then cannot see the module. Here is an example of what is happening.... I've deleted bits of the scan but you can see that the status of all the installed modules is OK but then some modules can't be reached with the scan!
Tuesday,06,January,2015,18:06:26:26904
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: TMBBG7NE3Dxxxxxxx License Plate:
Mileage: 19594km-12175mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 5F
VIN: TMBBG7NE3D0033243   Mileage: 19594km-12175miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012032501090000
   Shop #: WSC 73430 031 00125
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021AL.rod
   VCID: 2F43DF1476745459C61-807A
No fault code found.
Readiness: 0 0 0 0 0
Address 16: Steering wheel
Cannot be reached
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000512622
   Coding: 030100040B087300EF000648080F00010001000000000000000000000000
   Shop #: WSC 73430 790 00125
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear.rod
   VCID: 3449D0789F527781BB3-8061
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0100
   Serial number: 000000000B0356160413
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8446110403
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B76765D525220343E00
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B7BCB04426C2879EA9-807E
Address 42: Door Elect, Driver
Cannot be reached
Maybe teaching granny to suck eggs, but you did have the ignition on at the time didn't you?
Of course. I am able to code and access all installed modules, just not able to document/achieve a full autoscan!
It was just a thought (nay, a complete stab in the dark!) The wheel I believe is only powered when the ignition is on, hence the volume etc buttons don't work even when the radio is on.
AndyV may have some ideas - he seems to be very knowledgable on VCDS.. Me, I've only just got mine so still learning.
Just realised that I should have posted this in the VCDS forum... so have posted in there as well.
Do you have any doors open?
Also, reset all of the port and protocol options to default and re-test the interface then try again.
Beyond that, log it with Ross-Tech support
Protocols are set to normal Andy. I think I had the doors both open and closed when doing the scans. Both resulted in comm errors although different ones. Have just emailed Ross Tech.
Doors need to be closed and ignition on but engine not running.
Sent from my HTC One_M8 using Tapatalk
Still doing it with the doors closed. Able to recode all the tweaks that I want, even on modules that apparently can't be reached. RossTech support have asked me to a do a debug with a 1240 setting and send them all the debug files. I have done this and am awaiting a response.
Latest coding done was to stop the Light Assistant resetting itself...
A similar thing has happened to a Golf owner, not sure if it ever got sorted out
I think it may be sorted out Andy. Apparently some of the newer UDS modules do not respond properly to VCDS requests. I am now the proud owner (perhaps the first) of VCDS 14.11.6 to test, which I will do tomorrow.  Excellent RossTech support as usual.
Edited by DougL
Brilliant!
The odd thing is I have some significantly newer controllers that seem to work fine!
Couldn't wait to try it and unfortunately it didn't work. Last autoscan couldn't see 17 and 42, this scan couldn't see 3,8 and 42. Very odd. I think it might be my PC. Might try my old netbook! Here goes!
Turn off any antivirus and malware protection.
Did a perfect Autoscan from my old netbook. I wonder did windows defender cause a problem?
What AV do you have installed?
None. Use neither for online use. I gave the Lenovo to my father, who never used it. The little netbook was only ever used for VCDS and emailing the scans so none on it either. Normal machine is a Mac running Sophos AV, but obviously I can't run VCDS on that. (Probably could if I used an emulator..)
