Fitting FL hazard switch to pre FL
Quick question. Is it a straight swap to replace the hazard light switch in a pre face lift Octy to the face lift switch?
Thanks.
Yes, button is same, only disconnect and connect again, you must remove whole upper plastic with ventilation etx, disconnect cable to button and remove it from inside out. Or you can first remove button from cover and after that disconnect the cable. Absolutly no problem and you dond need any equipment:)
  • 5 weeks later...
Excellent, thanks for that.
