Another brake question
Hi
The brake pad warning light has come on.
I've ordered new discs and pads do I need to order a brake pad wear sensor as well?
The brake pad set should come with the sensor & wire & connector built into the pad,its fitted to the n/s/f only.
Strange one for u here I developed a squeal from front brakes so took the pads out to clean them up and there were no wear sensors on the front pads either side or any wires there to plug a wear sensor in too that was on a 62 plate Vrs blackline but my pre facelift had the wear sensors on that weird I thought
