What tt bits do i need?
Hi guys and girls,
Right I've had a good search but cant find the answer i need. A friend of mine is breaking a couple of audi tt 225s and a mk1 s3, so ive been looking into the front suspension for my vrs as my wishbone bushes are getting very tired. But do i just need the cast wishbones from either the tt or s3 or do i need the hubs, ball joints aswell? Also i understand they have a quick rack which will be a good mod but do they have a bigger front roll bar then the vrs?
Thanks Jack
Front ARB you'll be looking for the R32 version, 23mm I believe.
You will need . Hubs, wishbones , steering rack. Need to get VRS flange fitted to hub so may as well get new wheel bearings fitted at the same time. And also Superpro bushes with caster increase. Also if you are going to get stuff powdercoated two new ABS sensors as the old ones will break on removal. HTH.
