out of gear problem?
Hi,
Sometimes I cannot get my car out of 1.gear e.g. while waiting for green light, I have to press down the break-pedal to prevent it from driving even though the clutch pedal is pressed down?
The problem is still there, even after clutch+clutch release bearing replacement. :no:
Any suggestions to what it can be?
best regards
Bobbi
Denmark
(Octavia 1z5)
Master cylinder? Fluid leak? Air in the clutch system?
Just some possible causes.
Phil
I get the same sometimes or going reverse and then struggling to put into 1st. Usually realising clutch and pressing again helps.
Thank you Phil :happy: , maybe I should go for a master cylinder replacement.
could it be the flyweel?
