Which piggy back fuses do i need on a mk2 fabia
I think I used mini for mine. Used a switched live that was spare.
Sent from my SM-N9005 using Tapatalk
Defo mini blade pal, I just checked my purchase history.
They are mini.
I'm using the normal size for mine, found an empty slot that's ignition live so that's running both my dashcams.
You can use standard if you choose a fuse on the LHS of the box. I just found a switched live in the mini fuses.
How did you get the wire long enough to reach the rear of the car, did you have to extend the original wiring or a long wired 12v socket into the boot? I'm planning on using a 12v socket with a lengthened wire to the boot so I don't have to cut the dash cam wires. Got a drivepro 200 for the rear just looking for something for the front now, want one with gprs for speed and direction.
cheers lads
I simply used a 3m extension usb lead (female to male) and ran it up my a pillar and through the headlining to the rear. The piggy back is connected to a female cigarette socket (no idea what they are called) and the male socket has USB ports on them.
  • 4 weeks later...
Error entry..
