Want a bigger sub!!!!
I currently have a JVC KD-AVX1 HU and a Kenwood KSC-SW1 sub in the rear footwell BUT............The sub isnt powerful enough for my needs so I am after a bigger one.
However, I am a little pushed for space as I use my estate car to carry my tools and all manner of crap around the country. I want a powerful sub that can be shoe horned into the corner of the load area and that can be removed quickly if i need to put the seats down.
Running cables is a doddle so no issues there.
What do you think peeps? I am after recommendations if poss.
RE makes some big hitting subs, infact my mate was seling one. i'llsee if he's still selling it :)
Nice one, what are they like as far as physical dimensions and do they come with built in amps?
How about this bad boy?? >> Alpine SWD-2000? looks like the one for me :D
it isn't an active sub no ad although they aren't physically big they are heavy
i think this one weighs about 30kg
here you go
sub for sale
I'm really after an active sub with everything stuffed into a box that i can plug and play.
I'm way too lazy to build boxes and the like, just ask SWMBO, she will tell you.
ahwell
btw that is the small one :eek:
he s also selling another larger RE sub or
I think that would be overkill for me, my boss would love it if his car was full of sub and no tools.
Thanks anyway bengie :thumbup:
no worries, my local place deals with vibe active subs. they seem fine enough, gonna go looking for links for you
Rockford Fosgate use to make a rather loud *cough 1000WRMS 10" sub(DVC too) - wouldnt need a big box either, think they were around the
I'd be suprised if it was really 1000W RMS. Thats a lot for a little 10inch.
RF are awesome, gonna go link hunting now :D
I have a nearly new, single JL 12W3 up for grabs if you want (bought new in June for
how about this one :rofl:
Carbon fiber and glass fiber dust cap with aluminum honeycomb center
Expanded polypropylene cone with mica filler for reduced mass and increased stiffness
FEA designed progressive roll spider with 10 AWG integrated tinsel leads woven in to allow for 2.5” of linear cone movement one way
900 ounce strontium ferrite magnet with extended magnetic field gap technology and aluminum shorting ring
6.5” voice coil with a flat wound, long-excursion design incorporating 2.5” of x-max and 17 AWG high temperature aluminum wire
Aluminum heatsink to maintain the optimum voice-coil temperature
6,000 RMS, 12,000 peak music power
Sensitivity 94 dB @ 2.83V
Available in Dual 2 Ohm and Dual 4 ohm Voice Coils.
Mounting Depth 23"
Replacable cone for everyday SQL applications and competition SPL applications
Ok maybe more than most people need ;)
I knew they did one (mind you the one i was thinking was a diff model no) Top quality subs they are too ;)
:eek:....................
very good quality i agree but i have moved over to alpine :rolleyes:
alos very good subs, i got a pair in the bot and struggling to not stick another 2 in there as my amp will happily run another pair, that would make 1200W RMS from 4xDVC 12" :eek:
Oh my goodness!!!!!!!! That's mental!
I have a RE XXX12, it takes 1600rms, But I've seen them take over 5k rms before.
The key to a good sub is more to do with the box design than the actuall sub. You could spend
