interior light fuse
Just been looking in the manual and cant find any reference to an interior light fuse. anyone know which one it is? Car is an 07 Octavia vrs and none of the interior lights are working
I've got exact same problem, all of the interior roof lights don't work. I tried looking for the fuse but couldn't find it either. I don't know if it could be the comfort control module
If the switch on the mk2 is like on the mk1, there is an "Off" position that kills everything bar the red lights in the doors.
I've tried moving the switches to all the different positions and still nothing?
Drivers side fuse box. Should be item 15 on the fuse card, Brown, Rated at 7.5 amps.
Thats the one I replaced when my O/H lights were not working.
Paul
Thank you will have to give it a try
  • 1 year later...
My car also has an interior light issue, this includes the door lights.
None of them will switch on, what ever I try.
Everything else works as should, although, the passenger door lock will not unlock or lock the car.
Is this a common issue?
Are these symptoms related to each other?
