Fuel Flap issue
Hi All,
2012 Estate Elegance
Had the car 2 weeks and the Fuel Flap wont open, is this a common occurrence and is there a quick fix?
Edited by ANSuperb
Daft question, have you made sure the car is unlocked? Some people drive around with their doors locked for safety reasons, and if you then open the drivers door to get out at the petrol station forecourt using only the internal drivers door handle, all other doors remain locked, including the petrol flap.
Just in case you didn't know, if you press the fuel flap door against its spring whilst operating the central locking (with the remote) it will usually unlock the flap.
You may need several attempts, with different amounts of effort. Half of the flap's available in/out movement is probably best the position to try to unlock it.
Not a fix! But buys you some time (months?)
HTH
Edited by CombatWombat
It seems to be a common issue, I think someone posted that a replacement part is about £15-20.
The auto lock feature unlocks all doors and filler flap when you open the drivers door.
