Cruise Control for Octavia 1.6 Amb
I have gone through a few threads on fitting the cruise control for the Octy. However it seems that the models mentioned were mainly the vRS versions. Anyone know if I can have my car fitted by a VAG mechanic with just the stalk and connect the loom to the ecu and activate via the vag-com on the 74Kw 1.6 version just like in the diesels?
I have gone through a few threads on fitting the cruise control ... Anyone know if I can have my car fitted ... just the stalk and connect the loom to the ecu and activate via the vag-com on the 74Kw 1.6..
I dont think that is possible, unless your engine has a 'AZD' in the engine number.
Have a look at the table on this page to see if your engine is listed.You'll need your engine number, which should be on your V5.
http://www.golfmk4.co.uk/cc_compatibility_chart.htm
And other pointers here:
http://www.golfmk4.co.uk/cruise_control.htm
http://homepage.ntlworld.com/dgace/cruise_control.htm
HTH
Alan.
That's a really useful table. It doesn't list the ARX (fitted to the Octavia 1.8T DBW VVT 4X4), but there again it is for Golf variants. I have bookmarked it for future reference. :)
You need to confirm that your car is DBW (Drive By Wire). If it is then you should be ok but you will need the additional wiring loom as I believe this is only normally fitted to the TD's.
Also before you buy any parts have Cruise enabled in the ECU.
