comfort suspension
i have fabia s.e with kw suspension with apex 50mm springs
i want more comfortable driving from now.
what suspension may i choose?
Best to get the original Skoda Fabia springs.................for ground clearance or fit eibach -30mm springs for standard dampers.....then fit Koni FSD dampers, these work with standard springs & are very good!
I concur, another option if you are not overly interested in the aesthetics is to stay with the standard suspension completely. I have stayed with it for the same reason of comfort and find it quite acceptable and able when it is being hurried along. Enjoy!
I've ordered just a few hours ago a full set of Koni FSD for all 4 corners and I will be using them on the default springs .. I do really hope that everything will go as planed. :)
Should do, I ran those dampers on my Fabia for 6yrs, no problems! Still have full compression of damper as per factory ones when going through potholes. But going around corners they firstly compress like the factory ones, but go around a bit faster & they then firm up & the car stays more level. heavy braking, small amount firstly like factory dampers, then they firm up & much better stability.
Basically a bit like turbo lag, initial bit is like factory they the FSD bit kicks in & they go "sport".................you get used to it, but even on twisty roads I could not unsettle the dampers, very good!
I also ran the Factory springs, & powerflex bushes!
Edited by fabdavrav
Good info. How about on crappy roads? Do they perform better than the factory ones?
 Yes they do!
