CAYC DPF pressure sensor plug part number? matching socket and repair wires/seals?
Hi, as in topic, I need the part number for plug that connects to DPF pressure sensor on a 1.6TDI CR diesel (engine code CAYC). I also need a part number for a matching socket housing and the various seals/repair wires that go with both. Help with these part numbers will be much appreciated.
In case you wonder, I want to have a good look what my DPF pressure sensor is reporting without damaging any wires, basically I want to make a "DPF pressure sensor extension cord" so I can tap off the voltage.  I have just carried out post winter oil change due to fuel in oil at 3.36k  miles. Yes, the car is run on a lot of short trips, but the engine did not put any fuel into oil over spring-autumn 2014.
Edit:
Found the plug number, 3D0 973 703 and the repair wires 000 979 131 E. So now all I need is a matching socket + repair wires and seals - please help.
Edited by dieselV6
