Skoda Octavia VRS Remap Help Needed
I have recently bought a beautiful 2007 octavia vrs
it currently has awesome k&n induction with a heat shield and a dumb valve
value of both them and fitting costed £500 so it was professionally done
when i purchased the car he said it was remapped but no evidence was there
so if i get a dyno run how would i know it has been remapped will it be running 40bhp more?
and if it's remapped i want to go to stage 2
and getting it running at 260-270bhp will that be okay for the turbo ? as some other threads say anything over 280bhp need to change the turbo to k04
as the skodas have k03 turbos fitted
if i am able to get 260-270bhp without changing the turbo what will i need to get
and i dont really want a exhaust system due to the fact my is in good condition and saves me a lot of ££
You need a uprated high pressure fuel pump, and a uprated turbo down pipe to get the sort of bhp numbers you are looking at IIRC.
You'll be able to tell if it's remapped if the torque curve looks like a mountain and not like a mesa.  Ex factory the torque is artificially limited so it plateaus at about 2200rpm and stays flat until around 5000rpm then drops away.  WIth a remap the torque will continue to increase until about 4500-5000ish and then drop away.
For stage 2 (IMO)
upgraded inlet - tick
remaining
upgrade HPFP and add a new cam follower (check / replace the cam follower even if you stay stage 1)
Upgraded intercooler
3" downpipe & sports cat
3" catback exhaust
stage 2 software
Anything less & it's not really stage 2 IMO but you can pick & choose from that list & get your own stage 1.5.
After you've gone stage 2 then you'll need to review the capabilities of your tyres, wheels, suspension, engine mounts & brakes.  It's (almost) never ending. :-)
Have fun
ill go for stage 1.5
i want 260-270bhp i have been told i wont need to upgrade exhaust by the tuners maybe intercooler would help
also what is a cam follower?
cup shaped object between the fuel pump & the camshaft.  The case hardening can wear off.  It's worthwhile inspecting them or the result might be:
Thanks guys, people have said cambelt and pump will need to be changed at 120k
atm i have 92k will i be okay, as i was hoping to change it at 100k miles
it is 2006 octavia vrs and i want to remap it to 265bhp
