2007 Octavia Fault Codes
A friend of mine has just bought a 2007 Octavia 140pd and it has been scanned with VCDS with the following errors. I have looked on the Rosstech Wiki and have a general idea of the faults, but thought I would post here in case any of them are common fixes. I have just pasted the relevant info of the scan.
Thanks in advance
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 LD    HW: 03G 906 021 LD
   Component: R4 2,0L EDC G000SG  8514
   Revision: --H05---    Serial number: SKZ7Z0F3701648
   Coding: 0000072
   Shop #: WSC 73430 790 00000
   VCID: 6CD3C083361B
2 Faults Found:
012547 - Motor for Intake Manifold Flap (V157): Malfunction
               P3103 - 000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 15
                    Mileage: 207437 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:41:26
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.62 V
                    Bin. Bits: 00101100
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
001681 - Fan 1 Control Circuit: Short to GND
               P0691 - 000 -  -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 207437 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:41:38
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00101100
                    Temperature: 55.8∞C
                    Duty Cycle: 9.7 %
Readiness: 1 1 0 0 0
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004370139
   Coding: 418A0F030004140000110D000000000000087F075C
   VCID: 2B51039FF395
   Part No: 1Z2 955 119 A
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 73430
   Part No: 1K0 955 559 AE
   Component: RLS     250706 014  1201
   Coding: 00471077
   Shop #: WSC 73430
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 207437 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 01801A085283007F3F04850540085F96907CA0
   VCID: 83010B3FBB85
   Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Component:       NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
            000 -  -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 120
                    Time Indication: 0
ddress 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenks‰ulenmodul 035 0070
   Coding: 0000042
   VCID: 74E3D8E36E2B
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Most of those are common faults of you search on here. New alarm horn is easy enough, about £70 I believe - they have a life span of around six years.
Sounds like it needs a new fan as well, fan controller is built into the larger of the two fans and it is common for water to get in and do damage.
You might be able to get away with cleaning the internals of the wiper switch.
Manifold could be an expensive one although I think some people have just experienced breaks in wiring but to be safe you need to at least budget for a new manifold flap motor.
Not sure about the break lights.
