re wire standard disc changer??
has anyone had any success with getting the standard 6 disc boot changer to work with a blupunct single cd/mp3 changer?
the connecter plug is the same but it wont work. I have the wiring diagram for the blaupunct head unit connectors, but nothing for the boot changer?
is it possible?
has anyone done it?
be nice if it could be done..hate having to insert new cd's after using the boot changer...BUT it sounds better!
:confused:
There's a pin diagram here:
http://www.briskoda.net/forums/showthread.php?t=286
Which should show what each pin in the CD connector on the back of the Gamma (and hence probably the Symphony) does...
Whether rewiring it will work - it'll be an interesting experiment. :)
Rob.
hi, tried to follow your link but it just brings up talk about superbs ...
maybe its me coz I'm not that computer lit yet but is it the right link?
thanks for your help..will let you know if I manage to get it working!
cheers
rick (custard)
hi mike, got it that time..many thanx for the link. that may just be the job.now I need to go out into the cold garage and compare with the blapunct wiring diagram they (unusually) helpfully supplied.
will let you know if it works..now, wheres that fire extinguisher?
regards rick
hi again..seems pin 15 (clock) on sko wiring is not same as blaupunct..that lista pin 15 as permanent 12v..wonder what clock means??
