No power to radio, checked fuse?
Just got my car running, plugged a radio in and nothing happens.
Plugged it into another car and it works so know the radio is fine.
I checked all the fuses and they all seem ok, what els should I check?
Bump.
Had the same thing this morning.
The Radio uses two fuses, Fuse 10 (5 Amp) for Switched 12V, which the OEM radio didnt use, and Fuse 45 (15 or 20A IIRC)
I found the 5A was blown, so swapped it with the rear wiper fuse (10A) for the time being.
hope that helps
  • 2 months later...
Thanks Taylor 93.had the same thing as well today, both fuses replaced as both faulty.... Job done! :-)
