Blaupunkt Woodstock DAB 52
Description
The Woodstock DAB 52 is the world
Original Review : Mannyo
Pros: Excellent sound and build quality
Cons: Gets a bit hot
I purchased this along with a combined DAB/FM/AM aerial just after they became available in the UK. Installation is fairly easy but involved replacing the factory fit aerial to enable DAB reception. Once installed setup is easy and preseting of the tuner stations is a simple process.
The system can play MP3 files from CDR/RW and from MMC/SD cards. The unit also has DSC Disc management builtin which means it can control a CD Changer or the Blaupunkt CompactDrive. The addition of a 2nd Aux input lead allows you to listen to other audio sources (eg. laptop, mp3 player, dvd player) by simply connecting the lead to the lineout/phone socket on the audio source.
So far trouble free in 18 months of use.
