Quaife 02A ATB Helical LSD for Yeti
Do you know your Yeti's current transmission code? If so, then Quaife will be able to answer your question as to which ATB you need. If not, then I'm afraid they're only golden, not crystal.
As above, that's all you'll need when dealing with Quaife.
Thanks guys :)
Right, I've got all the info together for all those possibly wanting to upgrade the Diff on their 1.6tdi:
Gearbox code - LUB
Diff number - 0A4409021N
taper roller bearings - 096323981P
So it is an 02J-B Diff :) Quafie themselves hadn't a clue, between Mitchell Skoda and DarkSide Developments all the correct info was found :)
