Octavia 2006 combi suspension
Does anyone know if late model VRS combi suspension will fit my 2006 PD and if it will be slightly lower than my standard car? My shocks had advisories for slight misting on both rears last MOT so am expecting a fail. Either way with 160k on standard shocks and springs it is feeling a bit tired so could do with a change. I'd rather not go the coil over route if possible as I prefer factory parts.
the rear will be fine but the front shocks from a VRS won't fit a 1.9PD as VRS shocks 55mm whereas the 1.9PD shocks are 50mm (for the bit that slots into the hub)
to make them fit you will need to buy some new bilstein B4 (for sport suspension) 50mm shocks
