Front road spring change
Happy Easter Briskodans.
Please could someone post me a link to a 'how to' on replacing Octavia front road spring.
Assume I need a spring compressor, does anyone have one I could borrow or buy? East Anglia near Newmarket.
Thanks.
Mike - it sounds like your guys didn't have a hub spreader.
Front springs aren't overly hard but you do need spring compressors (unless fitting lowered springs - you can get away without compressors) and a home made hub spreader (grind flats on a bolt).
I usually undo the 3x ball joint bolts & pull the lower control arm down with a tie-down strap.  This allows the hub to drop low enough to clear the strut.
I would describe it as being harder than doing brakes but easier than pulling the inlet manifold off.  Probably the same level of difficulty as changing the intercooler.
